Hello all, a brief explanation, so i have an old VB Script that i need to convert into use within ArcGIS Pro.
the script should do the following, if there is a date in the "SurveyDay" field it should add on the number of months in the "Reinspection_Period" field and set a new date into the future within "SurveyDay" field based on the VB Script.
Regular inspected trees | 12/06/2019 12:05:19 | 36 | DateAdd ( "m", "Reinspection_Period" , "SurveyDay" ) |
so if the date was 12th June 2019 and we wanted to add 36 months onto this date it would set the date as 12th June 2022 HH:MM:SS the same if the number in this field was either a 6, 12 or any number typed in this "Reinspection_Period" Field
However i cannot get any script to work and anything i try generates <Null> values within the "SurveyDay" Field.
Can anyone help with the conversion from VB into either Arcade or Python expression when using the field calculate on the required column?
Thank you
