I am working on a realtime GIS python script I was given. I am working on simplifying it and just want to update features from a SQL view to a Feature service. The script runs successfully, but nothing updates. Ideally I just want to update the AGO feature layer only when a unit status changes in the SQL view. But a beginner at this and can't get it to work right. Any guidance would be appreciated. I know I could just do a truncate and append but at the speed I would want for this to update, I was having issues where the dashboard this feeds would update during the truncate and no data would be shown. Plus would like to use this else where in the future if possible on other projects.
Thanks, Justin!
import pyodbc
import os
from arcgis.gis import GIS
import arcgis
import sys
import arcgis.features
#lists for Units used during the update process
agol_units = []
current_units = []
unit_numbers = []
##select id,Unit,Status,Type,Juridiction,Division,LastUpdate
# SQL Query being passed through the ODBC connection
SQL_QUERY = """
select id,Unit,Status,StatusCategory,StatusRank,OOSReason,StatusChange,Type,Juridiction,Division,LastUpdate,Longitude,Latitude
from Reports_Database.dbo.Avail_Units_T
order by id
print ('Query Successful')
def ODBC_connect():
##SERVER = 'CADGIS.heartlandcad.net\CADGIS\SQLEXPRESS' # Server FQDN
SERVER = 'CADGIS\SQLEXPRESS' # Server FQDN
DATABASE = 'Reports_Database' # Database Name
##Connection string to pass in pyodbc connection request. Using Trusted_Connect=yes to have SQL Server Native Client ODBC driver use Windows Authentication of the account running the script
## Using the Windows Authentication of the account running the script allows for the use of a Managed Service Account to run the scheduled python script
connectionString = f'DRIVER={{ODBC Driver 17 for SQL Server}};SERVER={SERVER};DATABASE={DATABASE};Trusted_Connection=yes'
conn = pyodbc.connect(connectionString)
cursor = conn.cursor()
cursor.execute(SQL_QUERY)
records = cursor.fetchall()
for r in records:
record = [r.id,r.Unit,r.Status,r.StatusCategory,r.StatusRank,r.OOSReason,r.StatusChange,r.Type,r.Juridiction,r.Division,r.LastUpdate,r.Longitude,r.Latitude]
current_units.append(record)
unit_numbers.append(r.id)
print ('SQL Connection Successful')
def Portal_push():
#user = os.getenv('justin.nettleton') # System Environmental Variable Name for Username
#portal = os.getenv('https://www.arcgis.com') # System Environmental Variable Name for Portal URL
#gis = GIS(portal,user,password,use_gen_token=True)
gis = GIS("https://www.arcgis.com", "justin.nettleton", "******")
token = gis._con.token
agol_item = gis.content.get('c0011a3f169b45ca89f3142218fb4f3d') # ArcGIS Online Item ID
agoLayer = agol_item.layers[0]
agoFSet = agoLayer.query()#(where = '1=1')
ago_list = agoFSet.features
#Retrieving the unit numbers that are existing in the ArcGIS Online Feature Service
for exsting_unit in ago_list:
agol_units.append(exsting_unit)
# Updating units
for call in current_units:
if call in agol_units:
#unit_feature = [f for f in ago_list if f.attributes['id'] == call][0]
unit_dict = {"attributes":
{"id":call[0],
"Unit":call[1],
"Status":call[2],
"StatusCategory":call[3],
"StatusRank":call[4],
"OOSReason":call[5],
"StatusChange":call[6],
"Type":call[7],
"Juridiction":call[8].upper(),
"Division":call[9],
"LastUpdate":call[10]},
"geometry":
{"Longitude": call[11], "Latitude": call[12]}}
agoLayer.edit_attributes(updates=[unit_dict])
if __name__ == '__main__':
ODBC_connect()
Portal_push()
print ('Update Complete')
