Question:
I am a fairly new geodatabase administrator and am running into an issue regarding the geodatabase owner. I was told that the geodatabase is owned by/uses an 'SDE' schema, yet all the layers therein are prefixed with 'DBO', as in 'database.DBO.parcels'. If SDE was used, then wouldn't all the layers be prefixed with 'SDE'?
When I try to publish a layer topology, the analysis fails and throws a warning that the connected user 'SysAdmin' is not the dataset's owner, 'DBO'.
I do not have any 'DBO' user credentials, so I'm wondering if our IT department/SQL Database Administrator is mistaken. Is there a way to definitively tell with which user/schema the geodatabase was set up as?
Greg
