Hi.
I'm building a dashboard that tracks vacant properties based on property surveys that are conducted every month. Usually each survey is completed in a single day. I want to add a date selector that could be used to select a single or a range of dates to display data for. Right now data only shows up if you select a specific date on which the survey was recorded and I was wondering if there was a way to populate the following days with the data from last recorded survey.
Eg:
Survey #1 recorded 21 current vacant properties in the region on 21st of April, 2024
Survey #2 recorded 18 current vacant properties in the region on 24th of May, 2024
I want every date between these two surveys to show the data from Survey #1, while every date after 24th of May to show the data from Survey #2 (until the next survey is conducted).
Is there a way to achieve this without creating records for every single day?
Thank you.
