I added a domain to a hosted feature layer being used in a map for a couple Experience Builders.
This then broke the URL being used to display dynamic images.
I removed the list and it fixed the images, this is still a problem that this breaks this.
But the bigger problem is now I've reverted it, my Edit widget in ExB still seems to be broken and won't actually show the layer to update, no other settings have changed.
Any ideas, or is it simply a bug?
EDIT: In addtion, in this time frame the data was shared publicly, editing is not enabled but I have always been able to edit it, and "The layer owner, organization administrators, and members of shared update groups can edit a hosted feature layer or table layer’s contents even when editing is not explicitly enabled on the layer"
In the weirdest thing, if I add a random other layer to my map (I used a Survey123 layer), and it can be toggled off, and not set up with the Edit widget at all, for all intents and purposes it's not there, I can now edit the layers I need to. But if I remove that layer again, they all break again. That makes absolutely no sense to me hahaha.
