Hi, all. I am trying to open a saved map and place a marker by X,Y using URL parameters. When I pass the saved map ID it does not show the marker. If I use the same X,Y but not use the saved map (just open a new map) it places the marker and in the correct spot. I have tried about everyway that I can think of including passing the WKID. When passing the webmap ID it shows the layers and everything correctly just doesn't add the marker. This isn't a shared map otherwise I would post exactly what I am putting in the URL, but I will put "<masked>" in the ID.
https://storycogis.maps.arcgis.com/apps/mapviewer/index.html?webmap=<masked>?marker=-93.397070;41.905702;4326;;;Spot
Any help is greatly appreciated.
Matt
