Hi everyone,
I'm curious if it's doable in Experience Builder to leverage its built-in tools to create a feature where users can select a point on a map and then modify the data associated with that point through a pop-up.
Imagine you have a map with several points representing homes. You'd like users to be able to select a point and, within a pop-up window, edit various data fields. For example, they might want to adjust the believed value of the home. It would be particularly handy if users could select multiple points and edit a common field, such as "Dwelling Status," to mark them as occupied or vacant, all within one pop-up.
Is this functionality achievable in ArcGIS Experience Builder using its built-in tools and options?
