ArcGIS Pro, 3.2.2, advanced license, NVIDIA T1000 8GB. I'm using the tutorial and sample data at https://doc.arcgis.com/en/imagery/workflows/tutorials/create-drone-imagery-products-ortho-mapping.htm
I get a warning when creating the raster dataset "W > 2024-04-11T12:25:12.606: Warning: Cannot compute flight height from input parameters. Use default value: 1.000 m. [YUN_0040]".
Then when I try to run the block adjust, I get ERROR 999999
I > 2024-04-11T12:26:18.669: Computing initial tie points...
E > ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
E > Failed to extract feature points.
E > Parallel processing job timed out
E > Failed to execute (ComputeCameraModel).
Any suggestions? I've tried switching GPUs in Windows Graphics settings, setting Processor Type to CPU, changing the GPS accuracy, disabling the camera calibration, no change, always fails the block adjust after about 3 minutes.
