I'm very much a beginner with arcade, for my job I have moved over from ArcMap to Pro using parcel data that's been used for years. After getting everything else configured, I still can't get this script to work in arcade.
I'm giving in and made an account to seek some help because this is too advanced for me to grasp using youtube videos alone.
Here is the old VB that worked in ArcMap.
Function FindLabel ( [Parcels.PIN], [Parcels.ORIG_AC] , [Parcels.DEED_AC] , [Parcels.CALC_AC] )
pre = CInt(mid( [Parcels.PIN] ,23,3))
suf = (mid( [Parcels.PIN] ,27,3))
oa = [Parcels.ORIG_AC]
da = [Parcels.DEED_AC]
ca = [Parcels.CALC_AC]
If suf = 00000 Then
parid = pre
Else
parid = pre & "." & suf
End If
If oa > 0 And da > 0 And ca > 0 Then
FindLabel = parid & vbNewLine & oa & " Ac" & vbNewLine & da & " Ac(d)" & vbNewLine & ca & " Ac(c)"
ElseIf oa = 0 And da > 0 And ca > 0 Then
FindLabel = parid & vbNewLine & da & " Ac(d)" & vbNewLine & ca & " Ac(c)"
ElseIf oa = 0 And da = 0 And ca >0 Then
FindLabel = parid & vbNewLine & ca & " Ac(c)"
ElseIf oa = 0 And da = 0 And ca = 0 Then
FindLabel = parid
ElseIf oa > 0 And da = 0 And ca > 0 Then
FindLabel = parid & vbNewLine & oa & " Ac" & vbNewLine & ca & " Ac(c)"
ElseIf oa > 0 And da = 0 And ca = 0 Then
ElseIf oa = 0 And da > 0 And ca = 0 Then
Else
End If
End Function
What is in yellow is what I need to get it back to, what is in orange is what it looks like from the field data.
For the PIN, I'm trying to only display the last 3 numbers before the decimal, if there's only one number then I'd like it to return just that number ex: '023' = '23'. As well as any numbers after the decimal if they are not 0.
For the Acres, Calculated are geometry (gis) based after changes, if the deeded ac is greater than a 2% difference we display both calculated and deeded. If it's less, we display just the deeded. Sometimes we don't have deeded so I need it to always at least display the calculated. (Ignore original acres, don't need those.)
If anyone has references to point me too, or just any help at all I'd appreciate it. I've fallen behind on work because I'm having to fix and make adjustments in pro and it's been a mess. (The databases are cluttered, I get errors to update but they've been updated. I did reach out for help and ESRI has helped me but I just can't waste more time trying to learn it this moment. They (databases) need to be cleaned... bad. I simply don't have the time, I'd really like to make parcel fabrics eventually to make my work more efficient. I'm learning on the fly every day.)
