I have a fresh install of Arcgis Server 10.4.1 and geoevent extension on a new windows server 2012 R2 machine.
I have set up my input and output and services, when I send test data based on this link
https://community.esri.com/community/gis/enterprise-gis/geoevent/blog/2015/12/19/how-to-test-geoevent-verizon-networkfleet-connector Morakot Pilouk
I am getting the inputs but nothing coming out in the geoevent services in/out counts.....
I have tried running what RJ Sunderman suggested here Diagnostic utility for checking the status of the RabbitMQ platform service but I am getting errors there as well.
Running diagnostics ...
Exception in thread "main" com.esri.arcgis.discovery.json.JSONException: JSONObject["token"] not found.
at com.esri.arcgis.discovery.json.JSONObject.get(JSONObject.java:372)
at com.esri.arcgis.discovery.json.JSONObject.getString(JSONObject.java:499)
at com.esri.arcgis.diagnostics.RabbitMQDiag.runDiagnostics(RabbitMQDiag.java:150)
at com.esri.arcgis.diagnostics.RabbitMQDiag.main(RabbitMQDiag.java:461) |
Geoevent Log
Logger:
| net.jodah.lyra.internal.ConnectionHandler |
Message:
Failed to create connection cxn-42 java.net.ConnectException: Connection refused: connect
at java.net.DualStackPlainSocketImpl.connect0(Native Method)[:1.8.0_73]
at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:79)[:1.8.0_73]
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)[:1.8.0_73]
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)[:1.8.0_73]
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)[:1.8.0_73]
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)[:1.8.0_73]
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)[:1.8.0_73]
at java.net.Socket.connect(Socket.java:589)[:1.8.0_73]
at sun.security.ssl.SSLSocketImpl.connect(SSLSocketImpl.java:668)[:1.8.0_73]
at com.rabbitmq.client.impl.FrameHandlerFactory.create(FrameHandlerFactory.java:32)
[107:com.esri.ges.framework.messaging.jms-messaging:10.4.1]
at com.rabbitmq.client.ConnectionFactory.newConnection(ConnectionFactory.java:588)
at net.jodah.lyra.internal.ConnectionHandler$3.call(ConnectionHandler.java:233)
at net.jodah.lyra.internal.ConnectionHandler$3.call(ConnectionHandler.java:227)
at net.jodah.lyra.internal.RetryableResource.callWithRetries(RetryableResource.java:50)
at net.jodah.lyra.internal.ConnectionHandler.createConnection(ConnectionHandler.java:227)
at net.jodah.lyra.internal.ConnectionHandler.createConnection(ConnectionHandler.java:115)
at net.jodah.lyra.Connections.create(Connections.java:68)
at com.esri.ges.messaging.jms.amqp.AmqpMessagingFactory$ConnectionEstablisher.run(AmqpMessagingFactory.java:873)
at java.lang.Thread.run(Thread.java:745)[:1.8.0_73] |
Any thoughts or help would be greatly appreciated!!!
Tom
