I'm configuring a dashboard and intend the end product to allow the user to use the search bar in the Map to look up a specific record from a layer in the map.
In the web map that's the basis for the dashboard I have set the Application Settings to Enable Search By Layer and have removed the default search services.
However, in the dependent dashboard the search widget still shows the ArcGIS World Geocoding Service as the default in addition to the layer that I added. Is it possible to remove the default geocoding service from the search bar so that it's only searching by the layers that I designate?
