I have ArcMap, I create new gdb and copy the mdb data into the new gdb. ArcMap can read the new gdb data fine, put when I try to load it into pro I get this:
Why can ArcMap read from the new gdb but Pro can't? The part I copy form the mdb to the gdb is an entire feature dataset that contains many feature classes. The mdb data is from a utility company, so we're stuck with that format until they start using gdbs, which will likely be never.
