Hi. I'm in a college class and I have a project to read several multi-part coordinate files and create shapefiles from them.
The file format I am given is below.
I'm hung up on a few parts.
1: I can't bring the part name into a shapefile.
2. I am unable to use the existing spatial reference.
If I take a set single set of coordinates and save them into a file I can make a shapefile with the following code, but under no circumstance can I work on the file as it has been provided.
Can someone help me?
Brantley
Single part conversion. working
cursor = arcpy.da.InsertCursor(fc, ["SHAPE@"])
array = arcpy.Array()
point = arcpy.Point()
for line in fileinput.input(infile1):
point.ID, point.X, point.Y = line.split()
array.add(point)
polygon = arcpy.Polygon(array)
cursor.insertRow([polygon])
fileinput.close()
provided multipart text file. unable to convert/import to a shapefile.
Work Completed on: 7_8_2014
Spatial Reference: 43006
488597.653655, 4134910.76248
488813.848952, 4134609.01192
488904.303214, 4134480.54842
488938.462756, 4134422.3471
496198.193041, 4134565.19994
496312.413827, 4134568.14182
496433.652036, 4134568.08923
496559.933558, 4134547.91561
496782.196397, 4134527.70636
496923.636101, 4134512.56252
494434.480367, 4134742.03574
494610.098577, 4134679.72895
494726.29001, 4134689.71507
494872.793327, 4134704.71426
494963.626594, 4134548.72468
494995.829828, 4135127.64541
494978.929114, 4135325.68215
494974.480425, 4135410.81948
495046.57052, 4135567.60122
495127.628495, 4135675.08887
495222.19606, 4135804.97093
495307.786759, 4135979.66167
