I use the last version of js esri javascript 4.0 and I have a problem with the zoom out and pan. so I describe you the problem for each hardware :
- IPAD (IOS 9.3) - Safari : Zoom out with two fingers go out of the window (and then you can select an other tab after)
- IPHONE 6 (IOS 9.3) - Safari : When you do a Pan, all the screen move (buttons..) and this is bad experience for users
- IPHONE 6 (IOS 9.3) - Chrome : Same as 2 and the second problem is when you pan to bottom the page is reloaded.
For testing, you can try with the sample of Developers site :
Get started with MapView - Create a 2D map - 4.0
I tried to change the viewport but I didn't have success, such :
<meta name='viewport' content='initial-scale=1.0, maximum-scale=1.0, minimum-scale=1.0, user-scalable=no'>
Someone has an idea to fix it or this is a bug of js api 4?
(This is not a problem for Android mobile and tablet)
