Hello Community,
I am just learning ArcGIS Maps SDK for Javascript, and in the process, I am trying to create a simple application that should highlight the features after executing a query. The code is as follows :
require(["esri/config", "esri/Map", "esri/views/MapView", "esri/layers/FeatureLayer", "esri/widgets/Popup", "esri/widgets/Legend", "esri/widgets/LayerList", "esri/rest/query", "esri/rest/support/Query"], function (esriConfig, Map, MapView, FeatureLayer, Popup, Legend, LayerList, query, Query) {
esriConfig.apiKey = "xyz";
const colors = ["#d92b30", "#3cccb4", "#ffdf3c", "#c27c30", "#f260a1"];
const commonProperties = {
type: "simple-marker",
width: "2px",
style: "circle"
const gujarat = {
...commonProperties,
color: colors[0]
const odisha = {
color: colors[1]
const punjab = {
color: colors[2]
const tamilnadu = {
color: colors[3]
const other = {
color: colors[4]
const ptrenderer = {
type: "unique-value",
legendOptions:{
title: "State Name"
defaultSymbol: other,
defaultLabel: "Others",
field: "state",
uniqueValueInfos: [
value: "Gujarat", // code for Gujarat
symbol: gujarat,
label: "Gujarat"
value: "Odisha", // code for Odisha
symbol: odisha,
label: "Odisha"
value: "Punjab", // code for Punjab
symbol: punjab,
label: "Punjab"
value: "Tamil Nadu", // code for Tamil Nadu
symbol: tamilnadu,
label: "Tamil Nadu"
const params = new Query({
returnGeometry: true,
outFields: ["*"]
const map = new Map({
basemap: "arcgis-topographic"
const view = new MapView({
map: map,
center: [78.9629, 20.5937],
zoom: 5,
container: "viewDiv",
popup: new Popup({
defaultPopupTemplateEnabled : true
const featureLayer = new FeatureLayer({
url : "https://services6.arcgis.com/Cj6ppUYzylKGUnEi/arcgis/rest/services/India_Wetlands/FeatureServer",
renderer: ptrenderer
view.when(() => {
view.ui.add("optionsDiv", "bottom-right");
document.getElementById("doBtn").addEventListener("click", doQuery);
const attributeName = document.getElementById("attSelect");
const expressionSign = document.getElementById("signSelect");
const value = document.getElementById("valSelect");
function doQuery() {
// Clear the results from a previous query and close the popup if its open.
//featureLayer.removeAll();
if (view.popup.visible) {
view.closePopup();
params.where = attributeName.value + expressionSign.value + "'" + value.value + "'";
// executes the query and calls getResults() once the promise is resolved
// promiseRejected() is called if the promise is rejected
featureLayer.queryFeatures(params).then(getResults).catch(promiseRejected);
function getResults(results){
const symbol = {
color : [20, 30, 100, 0.5],
outline: {
color: "white",
width: .5
results.features.map((feature) => {
feature.symbol = symbol
return feature
// Called each time the promise is rejected
function promiseRejected(error) {
console.error("Promise rejected: ", error.message);
view.when(()=>{
const layerlist = new LayerList({
view : view
view.ui.add(layerlist, "top-right")
view.ui.add(new Legend({ view }), "bottom-left");
//const featureLayer = new FeatureLayer({
//url : "https://services6.arcgis.com/Cj6ppUYzylKGUnEi/arcgis/rest/services/India_Wetlands/FeatureServer",
//renderer: ptrenderer
const statesLayer = new FeatureLayer({
url: "https://livingatlas.esri.in/server1/rest/services/IAB/State/MapServer/0"
map.add(statesLayer,0)
map.add(featureLayer)
});The application loads just fine and am able to see the features however, after executing the query nothing happens and there is no error in the console as well.
I have used the following links as reference :
https://developers.arcgis.com/javascript/latest/tutorials/query-a-feature-layer-sql/
https://developers.arcgis.com/javascript/latest/sample-code/query/
I believe as both the links are referring to graphic layer and am using a feature layer, that could be causing some issue. Not sure what am I missing here.
Any suggestions would be helpful.
