I'm having trouble getting map areas to package for offline use in Field Maps. I've uploaded a series of blank datasets and some datasets that have features, and one that has two related tables. All the layers are published to the same organization with the same privileges and settings required for offline use, but no matter if I use Field Maps or the AGOL tool to try and create an offline area, it always fails.
I previously thought it was some rouge errors or data, but I've removed every layer one by one and it only packages once all the layers are removed and the ESRI basemap is all that's left.
I'm at a loss as to why this is still failing to create offline areas with feature datasets.
