In some tools, if you don't set the parallel processing factor as 0, the tools won't run successfully forever.
for example, use the Watershed tool with a large D8 raster and a large-scale lake raster, if you don't set the factor as 0, you won't get any result and you can't do any processing even if the world is destroyed.
How infuriating!
