I get shapefiles of easements from surveyors/engineers and need to check that the shapefile lines match the line calls (metes and bounds) on the survey plat. What is the best way to see the COGO direction and distance of an existing line feature? I've tried doing trace lines with the traverse tool but it always comes out different, is there anything else I should be checking? Projection, datum?
