I created a map in ArcGIS Pro containing 3 XY Event Layers which plots XY fields from Survey123 results table. XY Event layers are supposed to be dynamic. If I refresh the ArcGIS Pro window the data shown on the map updates as and when new data is added to the Survey123 forms.
I published this map as WebMap to my AGOL. Unfortunately, the data plotted on the WebMap does not get updated if new data is added in Survey123, even though I had added the option of refreshing the layers in the webmap every 0.5 min.
I am not sure whats going wrong here.
However, I must mention that the Survey results are not shared, whereas the WebMap is public. Is that creating the problem?
