Hello all,
We're currently transitioning from a geometric network to using a utility network, with the goal of having a UN web map stood up and functioning at the end of the year. However, due the transition and changing data structures, we don't have a steady UN web service to consume. With this in mind, we were considering exporting/deploying a snapshot copy of the current utility network structure to a file geodatabase, and then publishing that to portal for use in the web map. Is this workflow even possible? Attempts so far have errored out in various ways, so I'm just wondering if this is even the right direction to pursue.
