I am trying to write a python script to resample a batch of raster files. Just to check that I was getting the syntax/arguments for arcpy.Resample_management I tried to run it on a single file with the line shown below.
arcpy.Resample_management("T613_36_5000_2010.tif", "test.tif", "20", "Bilinear")
However it fails with an Error 999999 ExecuteError.
ExecuteError: ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
Failed to create raster dataset
Failed to execute (Resample).
What I noticed is that in the Geoprocessing window it showed the recent failures, clicking on there to bring up the tool in the GUI it brought up the same input settings I was trying to use in the python code and it worked fine (not sure if there is any fundamental differences in how the tools are executed between the GUI and a python notebook in ArcGIS).
Any help would be wonderful!
