We have some WMTS layers in our portal that contain a token in the url for access, but the service is not secured other than being shared to Org in our portal. If I add data in Earth and add that layer directly using the portal item, it loads as it should in Earth. If that same layer is in a webmap in portal and I add that webmap to Earth it prompts for credentials for some reason, and if that prompt is closed the layers fail to add. This is a problem because some our portal default basemaps include these layers, so as soon as you open Earth you get bombarded with 10 login prompts that shouldn't exist, and those basemaps are not available to use like they are in Portal maps or Pro. Are these not supported or is there some other change I can make to get them to work?
