Hi,We have graphicLayer that have line graphics drawn in 2D mode (map view). When we switch over to 3D Mode (scene view), we expect the drawn line graphics to be rendered correctly, however in Macbook Air Safari somehow it doesn't render correctly. Is it due to GPU performance or we doing something not right?this is the codepen link: https://codepen.io/azhaziqgoh/pen/xxMVNaN?editors=1000
map sdk version - 4.24
Hi @Muhammad_AzhaziqBin_Mohd_Azlan, thanks for posting your question here. It looks like you're working with version 4.24. The current version is 4.28. When I tried with the latest version, it looks like the issue you are seeing is fixed: https://codepen.io/noash/pen/ExryPLw?editors=1000
I'd recommend updating to the latest version of the ArcGIS Maps SDK for JavaScript, as this will contain many fixes and enhancements .
i see. notedit's quite big application to upgrade to 4.28 at this stage. We need to plan for proper sprint to ensure nothing break.I'll advice this to my client as known issue and limitation for now and will fix it once we upgrade the API version.@Noah-Sager , just curious is it happening due to the physical hardware requirement?
Přihlášení členové mohou přispívat, sledovat aktualizace a další. Jste tu noví? Zaregistrujte si bezplatný účet.
