Hi I am working on a process of producing some maps for a process we have to do at work
I am just struggling to get the zoom to layer to work. The rest of the script works fine.#
#buffer set up
Holdings = 'N:\GIS\Projects\AA_Leith_Hawkins_TestBed\Search_Cursor\Search_Cursor.gdb\Data\Holdings'
distances = [1000, 4000]
unit = "Meters"
#Make a feature layer
arcpy.MakeFeatureLayer_management(Holdings,'Holdings_Layer')
#searchcursor for evey row in dataset
with arcpy.da.SearchCursor(Holdings, ['Holding_Reference_Number'])as Holdings_Ref_cursor:
for row in Holdings_Ref_cursor:
print row[0]
query = "Holding_Reference_Number = " + str(row[0])
print query
File_output = file_workspace+ '\\' 'Buffer_'+str(row[0])
#print File_output
#PNG file outp put location
#Select Feature using the reference number from holdings layer
arcpy.SelectLayerByAttribute_management('Holdings_Layer', 'NEW_SELECTION',"Holding_Reference_Number = " + str(row[0]))
# Export holding to geodatabase
Holding_Boundary = file_workspace+ '\\' 'Holding_'+str(row[0])
arcpy.management.CopyFeatures('Holdings_Layer', Holding_Boundary)
#Mutliple ring Buffer using Selected Features
arcpy.MultipleRingBuffer_analysis('Holdings_Layer', File_output, distances, unit, "", "ALL")
arcpy.MakeFeatureLayer_management(File_output, 'Buffer_Layer')
#arcpy.Buffer_analysis("Holdings_Layer", ofc, var_Buffer, "FULL", "ROUND", "ALL", "")
print 'Buffer complete'
#Intersect Features
Intersect_out_feaatures = file_workspace+ '\\' 'Intersect_'+str(row[0])
arcpy.Intersect_analysis([Holdings,File_output],Intersect_out_feaatures,"","", "INPUT")
print "intersect Complete"
#print Png_output
#add Layers to the Map
mxd = arcpy.mapping.MapDocument('N:\\GIS\Projects\\AA_Leith_Hawkins_TestBed\\Search_Cursor\\Search_Cursor_mxd.mxd')
df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
addLayer = arcpy.mapping.Layer(File_output)
addLayer2 = arcpy.mapping.Layer(Holding_Boundary)
addLayer3 = arcpy.mapping.Layer(Intersect_out_feaatures)
arcpy.mapping.AddLayer(df, addLayer, "TOP")
print 'Buffer to map'
arcpy.mapping.AddLayer(df, addLayer2, "TOP")
print 'Holding to Map'
arcpy.mapping.AddLayer(df, addLayer3, "TOP")
print 'Intersect out Features to Map'
#zoom to layer
Selection = 'distance = 4000'
print Selection
lyr = arcpy.mapping.ListLayers(mxd,addLayer, df)[0]
extent = lyr.getExtent()
#arcpy.SelectLayerByAttribute_management('Buffer_Layer', 'NEW_SELECTION', Selection)
df.extent = extent
#Export Map to PNG File
Png_output = "N:\\GIS\Projects\\AA_Leith_Hawkins_TestBed\\" + str(row[0]) + '.png'
arcpy.mapping.ExportToPNG(mxd,Png_output)
print 'Map Created'
del mxdwhen ever I run it I am getting told my
File "N:\GIS\Projects\AA_Leith_Hawkins_TestBed\Search_Cursor\Script\SearchCUrsor.py", line 66, in <module>
IndexError: list index out of range
its most liekly a very simple error but I cant seem to get my head around the syntax to make it work
Any suggestions
