I am having a problem while trying to register enterprise geodatabase using python in ArcGIS Pro 3.1.1, I get the following error message:
RuntimeError: Cannot open AGS server connection.
I use arcpy.AddDataStoreItem method.The file is ok, I connect to a server using it. The server is federated with the Portal. I read somewhere that it was a known bug back there.
I have dozens of geodatabase connections (different users/schemas) and would not like to do it manually.
Any ideas? I did not find geoprocessing tool to do that either.
Thanks, Bart
