I'm at a total loss. I have a layer with a few basic objects. All the objects are under 75 feet high. In the elevation settings tab for the layer properties I have these objects set to relative to ground, the height field selected for the z-value, the units set to USFeet and yet these objects are rendering as being tall enough to probably reach low earth orbit. The objects are also not even close to rendering their heights relative to each other either. One of the shorter objects is rending about 20 times as tall as the tallest object.
I'm at a total loss as to what the solution is.
