Ever since I upgraded ArcGIS Pro from 2.9 to the 3.x environment, I have found the 3D Buildings solution lacking in several ways compared to its predecessor. For one, I find the solution riddled with problems. The more noticeable one is waiting for one of the steps to work only to be greeted with an error message.
Error in file name: <path>\ArcGIS\3DBasemaps\scripts\bm_common_lib.py
with error message: AttributeError: Object: Error in parsing arguments for Exists
ERROR:root:Error on line 2363
ERROR:root:Error in file name: C:\Users\slfernandez\Documents\ArcGIS\3DBasemaps\scripts\bm_common_lib.py
ERROR:root:with error message: AttributeError: Object: Error in parsing arguments for Exists
If you are lucky enough to get past the steps, there aren't any 3D buildings being created. Yes, I have followed the instructions (i.e. lesson plan) for the solution.
Another thing lacking is the ability to create trees using the data you just used to create buildings. This was a great function to add something extra to your presentation. That functionality, or task, has been removed.
Not sure why the 3D Buildings changed, but I am not satisfied with the current functionality. The ArcGIS Pro 2.9 version was leaps and bounds better than what we have now.
