I've been using the school locator solution since v1. I'm starting the process to upgrade to v2 to take advantage of the ability to include bus stops data. The problem I'm running into is that the way that the locator is configured, it's only looking for elementary, middle and high schools. Our district has a combination of K-5th grade, K-8th grade, Middle and High schools. I've been able to add these as domain values in the hosted feature services and work with them in the schools data management aprx, but when I try to configure the web maps or hub sites, I still only see elementary, middle and high schools as options. I was able to overwrite the web map with the new version in my screenshot, but I'm at a loss on how to configure everything in the instant apps and hub sites. The instant apps seem to be using the nearby tool, when what I need is zone lookup. I only want to see the schools (K5, MS, HS) within the attendance zones that the searched address is located in (and only the bus stops associated with those schools), not all the schools, attendance zones and bus stops within a search radius. Is this possible with the solution at v2? Any help would be appreciated.
