I am having issues with the way a feature layer is displaying. It seems to randomly order the features which leads to features that should be on top being obscured. The symbology was all set in ArcGIS Pro and the features were displayed in the correct order. Once the map service is published into my organization's Enterprise environment, the feature order is reshuffled.
I understand there is a solution to this in the latest versions of Enterprise:
https://enterprise.arcgis.com/en/portal/latest/use/set-feature-display-order.htm
My organization is still a bit out from implementing Enterprise 11.0 so I'm looking for a solution in our current environment of 10.9.1.
I came across some advice that a feature's object ID would dictate the order in which it is drawn by default. This appears to be the case for drawing the feature layer in Map Viewer right now with lower IDs on the bottom. Though I'm not sure if this is always the case. However, we still use Map Viewer Classic at times and the object ID is not determining the drawing order there. Is there a more effective way to workaround the drawing tendencies in ArcGIS Enterprise and get the map to follow the order laid out in ArcGIS Pro?
