I get the following error in Chrome when trying to implement the PrintTemplate.Uncaught TypeError: Cannot read property 'showAttribution' of undefinedI have showAttribution set to true for both my map and the print template. Any ideas?
// create the print template
var template = new esri.tasks.PrintTemplate();
template.layout = dijit.byId("mapLayout").value;
template.label = "Test";
template.format = dijit.byId("imageType").value;
if (dijit.byId("printLegend").checked){
template.layoutOptions = {
"titleText": dijit.byId("mapTitle").value,
"authorText": dijit.byId("printAuthor").value,
"copyrightText": dijit.byId("printCopyright").value,
"scaleBarUnit": dijit.byId("printScale").value
else {
template.preserveScale = true;
template.showAttribution = true;
//var printTaskURL = ndhx.config.printURL;
var printTaskURL = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task";
// var printer = new esri.dijit.Print({
// "map": ndhx.map,
// url: printTaskURL
// }, dojo.byId("print_button"));
ndhx.printer = new esri.dijit.Print({
"map": ndhx.map,
"templates": template,
url: printTaskURL
ndhx.printer.startup();
dojo.connect(ndhx.printer,'onPrintStart',function(){
console.log('The print operation has started');
dojo.connect(printer,'onError',function(error){
dojo.connect(printer,'onPrintComplete',function(value){
console.log('The url to the print image is : ' + value.url);
