-Goal: I am trying to create a script to access a layer on portal and clone it. After cloning it I would like to overwrite a layer in either a SQL database or back in portal.
-Reason: As the original layer updates I would like to run the script to update the copy in which I have view layers created from.
-I have been able to copy the layer and publish it to portal using to_featurelayer()
The issue is that the layer will not overwrite the existing layer in portal.
Here is the code I have been trying:
def overwrite_existing_layer(source_layer_name,feature_service_id,copy_layer_name):
try:
# Connect to the ArcGIS Portal
gis = GIS('pro')
# Retrieve the feature layer you want to clone
source_layer = gis.content.search(source_layer_name, item_type="Feature Layer")[0]
# Create a temporary copy of the layer
temporary_copy = source_layer.layers[0].query()
# Creat Pandas df from temporary copy
temp_sdf = temporary_copy.sdf
# Create a dictionary for the properties of to_featurelayer method
fl_properties = {
'layer': 0,
'featureServiceId': feature_service_id
# Overwrite the feature layer
new_layer = temp_sdf.spatial.to_featurelayer(title=copy_layer_name, overwrite=True, service={'layer': 0, 'featureServiceId': feature_service_id})
print("Temporary copy overwritten in SQL database.")
print('Finished running script')
except Exception as e:
# Handle any errors that occur during the process
print(f"An error occurred: {str(e)}")The script runs fine but does not overwrite the existing layer. I have the correct feature_service_id from the existing layer in portal but am not sure why it does not recognize the existing layer.
