Hi!
This might be a simple problem, but I keep getting stuck.
So, I have many polygons (about 500). A mass amount of points overlaps these polygons. I want to select only the polygons that intersect with less than 5 points (0 to 5). Once I select these polygons I want to remove them from the map.
I have read up on the SQL (https://community.esri.com/t5/arcgis-pro-questions/perform-a-sql-count-in-calculate-field/td-p/1133936) just an example, and seem to keep running into problems. I feel like this should be an easy solution, but I keep getting stuck!
