Hi -
I've seen many posts about scale-based symbology using Arcade (e.g. change the point size). I was wondering if it was possible to control a layer's transparency via Arcade so that a layer becomes more transparent as a user zooms in on a map.
Currently, I have two copies of the same layer in my map - one is opaque and the other is semi-transparent. As the user zooms in on the map, the opaque version disappears and is 'replaced' by the semi-transparent version.
Ideally, I'd like to use Arcade to change the transparency of a single layer as the user zooms in. This would help immensely as I am using my map in Experience Builder and the filter widget can only be applied to one layer.
Any advice would be appreciated,
