I've followed the user guide provided by ESRI UK to install the latest coordinate systems and transformations data from myesri: https://communityhub.esriuk.com/technicalsupport/2017/2/21/adding-the-ostn15-ntv2-transformation#commenting
The default location for the transformation files is C:\Program Files\ArcGIS\Server\pedata
However, the data is installing to C:\Program Files (x86)\ArcGIS\CoordinateSystemsData\pedata
Do I need to migrate the files over to the default location, or will the Portal automatically pick up this location?
Using Enterprise 10.9.1.
EDIT: I tested publishing an OSGB service without moving the files into the default directory and the service didn't pick up the new transformation. I then copied the .gsb files into the default folder and published a new map service, which did successfully pick up the transformation.
What's going on here? How can I not find clear concise instructions for the correct way to do this online?
