Need to make maps for PNG files I georeferenced and some vector layers, each layer lies within a georeferenced PNG. They are small (around 300 kB) files. After georeferencing them, they tend to dissapear when their feature layer is set to visible and I switch on/off other raster layer in same Map. Building pyramids, putting the PNG into other map or project or using raster made by exporting it doesn´t help. Even when the PNG/exported raster is visible in layout when I try to export the layout, only vector layers are visible in the output. Extent of the layout is correct, the problem is in the raster file.
