ArcGIS Pro 2.6.8; Oracle 18c 10.7.1 EGDB; SDO_GEOMETRY database view:
I have a database view (not registered with the GDB) that I've added to a map. I've spent some time configuring various layer properties including symbols, labels, joins, definition queries, etc.
I need to make a change to the view: Add a new field to the view by using a SQL Client. Now, I want the new field to show up in the attribute table in ArcGIS Pro.
As far as I can tell, there isn't a way to refresh the layer's schema so that the new field shows up in the attribute table.
I tried:
- Refresh button in the attribute table.
- Closing and re-opening the attribute table.
- Changing the data source in the properties (same source as before).
- Closing ArcGIS Pro and re-opening the map document.
But I still don't see the new field in the attribute table.
I would prefer not to remove the view feature layer from the Contents pane and re-add it, because then I would lose all my properties that I've set up. I'm aware that there is a geoprocessing tool to import the symbology from an old layer to a new layer. Which is good. But symbology is just one of many properties that I set up; I'm not aware of a way to transfer ALL properties from one layer to another.
Could functionality be added for refreshing the schema of an existing layer that is based on a view?
Thanks.
Related: Contents — Apply all properties from one layer to a different layer
