Hi,I need to use Dojo 1.9 in my page since it fixed some Bounding Box bugs in version 1.8.3. ArcGIS currently uses 1.8.3, so I need to use both versions of Dojo at the same time in my page.I'm new to Dojo, so I don't fully understand the configuration process, but I've tried to rename the Dojo namespace used by ArcGIS with this dojoConfig:var arcgisMap = { dojo: "dojoArcgis", dijit: "dijitArcgis", dojox: "dojoxArcgis" };
var dojoConfig = { //required for custom extensions to ArcGis (e.g. the cluster layer)
parseOnLoad: true,
packages: [
{ "name": "dojoArcgis", "location": 'http://serverapi.arcgisonline.com/jsapi/arcgis/3.5', packageMap: arcgisMap },
{ "name": "dijitArcgis", "location": 'http://serverapi.arcgisonline.com/jsapi/arcgis/3.5', packageMap: arcgisMap },
{ "name": "dojoxArcgis", "location": 'http://serverapi.arcgisonline.com/jsapi/arcgis/3.5', packageMap: arcgisMap },
{ "name": "Clustering", "location": '@Url.Content("~/Scripts/map/CustomArcGis/Clustering")' }
But when I call dojoArcgis.require("esri.map");
I get the error 'dojoArcgis' is undefined.Could somebody point me to what I'm doing wrong and maybe put here some code that show how to configure Dojo?Thanks.Lutfi
