Hi all,
I just have set up the ArcGIS Monitor 2023.0 on my system. It works quite well.
I have a problem though with implementing the SSL Certificate which we use with the DNS within the Monitor Admin panel.
When I save (and force restart) the server, the server hangs, won't start anymore (not the Localhost, not my own Web Context URL, etc.). It starts, but stops almost instantly.
I want to bypass this to make a rewrite rule (so in this case name.dnsname.nl/arcgis needs to point to name.dnsname.com:30443/arcgis) so that I can bind the certificate to the 443 port (https) of the default server. But that didn't work too (maybe I did something wrong with the rewrite rule).
Can someone help me with this? Thanks in advance,
