After setting up the agm database and user, I try to connect in the server setup dialog and get this error:
Knex: Timeout acquiring a connection. The pool is probably full. Are you missing a .transacting(trx) call?
Hi Daniel,
Please try restarting both the ArcGIS Monitor and Postgres services and then running through the setup again.
Josh
Thank you Josh - that worked
hi,
just installed it on Redhat Enterprise 8 and have same issue even after rebooting system. Any other suggestions?
Mark
Re-starting both Database and Monitor fixed the issue on our side too, thanks
Přihlášení členové mohou přispívat, sledovat aktualizace a další. Jste tu noví? Zaregistrujte si bezplatný účet.
