Hi!
We need to duplicate our esri environment with all data available on another esri deployment for test/development purposes. Esri enterprise deployment is done using AWS CloudFormation, so we tried to create one more environment using AWS CF too. So we have such setup now:
esri.foo.bar.com (old env)
esri-test.foo.bar.com (new env)
Then, we took backup from old env using webgisdr and tried to restore it on new environment, as a result we get this error:
Failed to validate the publicPortalURL for Portal for ArcGIS. The publicPortalURL in the web GIS backup does not match the publicPortalURL in the current web GIS
I tried to manipulate /etc/hosts/ file to make webgisdr think that URL from backup is resolving to current ArcGIS deployment as it said in esri docs. But it’s not working, so I think webgisdr makes an additional check of which URL assigned to esri deployment.
So my question is - is it possible to duplicate esri data on new environment created by AWS CloudFormation using webgisdr tool? Because as I understand - all that manipulation with /etc/hosts/, aliases etc make no sense since you installed esri software.
