I am trying to set up a custom URL using URL parameters in Appbuilder. I want the map to center and zoom on particular point that has a given value for the Accession field.
Using the Sharing widget, I got this custom URL: https://mesacc.maps.arcgis.com/apps/instant/basic/index.html?appid=654001f435f4486daa23196867b76673&locale=en¢er=-111.8694;33.3907&level=17&selectedFeature=18604e54e23-layer-2;556
You can see it's focused on a feature with the Accession value of 2017-1109.
I have tried to follow the instructions here to set up the correct parameters, but it fails every time. How do I set it up so the URL will center and zoom on this particular feature?
I will be linking from a database using a formula field that fills in the unique accession number, so querying by ObjectId or a similar ID field won't work.
