Hi all,
I am trying to determine the best way to set up a combined sewer + stormwater network, as they are not designed separately in my area. Could you help be with some conceptual aspects, please?
- My idea is to start from a sewer network and to add a tier specifically for stormwater drainage, as I need these two networks to be connected in the topology. Do you think it is a good way to start or is there a smarter way?
- I wanted to start from the ArcGIS Solutions Asset packages for sewer network and stormwater network. But after I applied both asset packages one after the other to my network, there were two sets of feature classes created (e.g. SewerDevice and StormwaterDevice). I’d like the two asset packages to be applied to a single domain. Is it possible to combine the two packages into one, instead of creating two separate domain networks?
- I noticed that the sewer solution is defined as hierarchical and the stormwater solution as partitioned. Why is that so? I don’t quite grasp why there is a distinction in the first place, but I would have expected, at least, that these two should be of the same type. What is the purpose of this distinction between hierarchical and partitioned networks?
Thanks in advance for your input.
