Hi. I have a project that could benefit from the Sidebar instant application. I have used this application in the past. I no longer see Sidebar as an option in the Instant App selector. Is this particular application no longer available?
I need a simple application that places the pop-up on the side (not floating) and allows one to access Survey123 via a link in the pop-up. In this link, we are also passing data into fields in the Survey form. The old Basic Viewer application sort of works, except when I set the pop-up to lock on the side, the pop-up is empty except for the Survey link. If the pop-up is floating, then all content is visible as is the Survey123 link. In either pop-up locations, when I click the link, the survey opens, including passing data into the form. The Minimalist app works too, almost. The pop-up is anchored on the left and shows the content and the Survey link. However, when I click on the Survey link, none of the data are passed into the survey form. And I cannot change the reference basemap in this application.
Any ideas, thoughts, help would be much appreciated. Sincerely, Jay
