Hi everyone! This is my first ever post, fingers crossed it makes sense.
We're trying to use the geoenrichment service to get walking distance around specific coordinates, and to get demographic data. We're using some code written about 9 months ago by someone no longer with the company. It used to work, but for some reason it no longer works. It may be an issue with the updated API, but we've been back and forth with the technical support team and we're struggling. So, I wanted to see if anyone's had this issue before!
Here are the components of our request.
headers: {'Content-type': 'application/x-www-form-urlencoded; charset=utf-8'}
studyAreas: [{'geometry': {'x': 117.09510729999998, 'y': 38.9856735}}, {'geometry': {'x': 117.09510729999998, 'y': 39.18567349999999}}, {'geometry': {'x': 117.29510730000003, 'y': 38.9856735}}, {'geometry': {'x': 117.29510730000003, 'y': 39.18567349999999}}]
studyAreasOptions: {'areaType': 'NetworkServiceArea', 'bufferUnits': 'Minutes', 'bufferRadii': [20], 'travel_mode': 'Walking'}
payload: {'f': 'json', 'token': 'xyz', 'inSR': 4326, 'outSR': 4326, 'returnGeometry': True, 'studyAreas': '[{"geometry": {"x": 117.09510729999998, "y": 38.9856735}}, {"geometry": {"x": 117.09510729999998, "y": 39.18567349999999}}, {"geometry": {"x": 117.29510730000003, "y": 38.9856735}}, {"geometry": {"x": 117.29510730000003, "y": 39.18567349999999}}]', 'studyAreasOptions': '{"areaType": "NetworkServiceArea", "bufferUnits": "Minutes", "bufferRadii": [20], "travel_mode": "Walking"}', 'ForStorage': False}
And here is the response that we get from ArcGIS. As you can see, we receive an "Internal error". If you have any ideas about why this is happening, or maybe another better way to get access to walking distances around a coordinate (that are not linked to
response_json: {'results': [{'paramName': 'GeoEnrichmentResult', 'dataType': 'GeoEnrichmentResult', 'value': {'version': '2.0', 'FeatureSet': []}}], 'messages': [{'description': 'Study area at [0] was ignored. Failed to build network service area. Reason: Internal error.', 'id': 20010208, 'type': 'esriJobMessageTypeError'}, {'description': 'Study area at [3] was ignored. Failed to build network service area. Reason: Internal error.', 'id': 20010208, 'type': 'esriJobMessageTypeError'}, {'description': 'Study area at [1] was ignored. Failed to build network service area. Reason: Internal error.', 'id': 20010208, 'type': 'esriJobMessageTypeError'}, {'description': 'Study area at [2] was ignored. Failed to build network service area. Reason: Internal error.', 'id': 20010208, 'type': 'esriJobMessageTypeError'}]}
