We've run into a design challenge for implementing an embedded map product into an existing webpage. Originally, I had a webmap viewer with search configured on each of the layers/services loaded in it. Since then we had migrated to instead use the Minimialist WAB template because of the way the webmap viewer requires url parameters to perform searches onLoad of the embedded map.
Now we are faced with the problem of configuring multiple search layers on the Minimalist template. That is, using the WAB builder online, I can only configure 1 search layer parameter.
Is there a solution or workaround to configure more search layers? Is there anything in the JSON of hosted WAB app I can fudge in order to get this to work?
