I want to make a ArcGIS map in Unity with C++. Because with this instead of the Map Creator i can change the visibility of layers in the play modus i read. I follow the tutorial : https://developers.arcgis.com/unity/maps/tutorials/display-a-map-api/#prepare-the-script
And this i my code now:
using Esri.ArcGISMapsSDK.Components;
using Esri.ArcGISMapsSDK.Samples.Components;
using Esri.ArcGISMapsSDK.Utils.GeoCoord;
using Esri.GameEngine.Extent;
using Esri.GameEngine.Geometry;
using Esri.Unity;
using UnityEngine;
using System;
[ExecuteAlways]
public string APIKey = "";
private ArcGISMapComponent arcGISMapComponent;
private ArcGISPoint geographicCoordinates = new ArcGISPoint(-74.054921, 40.691242, 3000, ArcGISSpatialReference.WGS84());
private void CreateArcGISMapComponent()
arcGISMapComponent = FindObjectOfType<ArcGISMapComponent>();
if (!arcGISMapComponent)
var arcGISMapGameObject = new GameObject("ArcGISMap");
arcGISMapComponent = arcGISMapGameObject.AddComponent<ArcGISMapComponent>();
arcGISMapComponent.OriginPosition = geographicCoordinates;
arcGISMapComponent.MapType = Esri.GameEngine.Map.ArcGISMapType.Local;
arcGISMapComponent.MapTypeChanged += new ArcGISMapComponent.MapTypeChangedEventHandler(CreateArcGISMap);
public void CreateArcGISMap()
var arcGISMap = new Esri.GameEngine.Map.ArcGISMap(arcGISMapComponent.MapType);
arcGISMap.Basemap = Esri.GameEngine.Map.ArcGISBasemap.CreateImagery(APIKey);
arcGISMap.Elevation = new Esri.GameEngine.Map.ArcGISMapElevation(new Esri.GameEngine.Elevation.ArcGISImageElevationSource("https://elevation3d.arcgis.com/arcgis/rest/services/WorldElevation3D/Terrain3D/ImageServer", "Elevation", ""));
var layer_1 = new Esri.GameEngine.Layers.ArcGISImageLayer("https://tiles.arcgis.com/tiles/nGt4QxSblgDfeJn9/arcgis/rest/services/UrbanObservatory_NYC_TransitFrequency/MapServer", "MyLayer_1", 1.0f, true, "");
arcGISMap.Layers.Add(layer_1);
var layer_2 = new Esri.GameEngine.Layers.ArcGISImageLayer("https://tiles.arcgis.com/tiles/nGt4QxSblgDfeJn9/arcgis/rest/services/New_York_Industrial/MapServer", "MyLayer_2", 1.0f, true, "");
arcGISMap.Layers.Add(layer_2);
var layer_3 = new Esri.GameEngine.Layers.ArcGISImageLayer("https://tiles.arcgis.com/tiles/4yjifSiIG17X0gW4/arcgis/rest/services/NewYorkCity_PopDensity/MapServer", "MyLayer_3", 1.0f, true, "");
arcGISMap.Layers.Add(layer_3);
var buildingLayer = new Esri.GameEngine.Layers.ArcGIS3DObjectSceneLayer("https://tiles.arcgis.com/tiles/P3ePLMYs2RVChkJx/arcgis/rest/services/Buildings_NewYork_17/SceneServer", "Building Layer", 1.0f, true, "");
arcGISMap.Layers.Add(buildingLayer);
var extentCenter = new Esri.GameEngine.Geometry.ArcGISPoint(-74.054921, 40.691242, 3000, ArcGISSpatialReference.WGS84());
var extent = new ArcGISExtentCircle(extentCenter, 100000);
arcGISMap.ClippingArea = extent;
arcGISMapComponent.View.Map = arcGISMap;
private ArcGISCameraComponent cameraComponent;
private void CreateArcGISCamera()
cameraComponent = Camera.main.gameObject.GetComponent<ArcGISCameraComponent>();
if (!cameraComponent)
var cameraGameObject = Camera.main.gameObject;
cameraGameObject.transform.SetParent(arcGISMapComponent.transform, false);
cameraComponent = cameraGameObject.AddComponent<ArcGISCameraComponent>();
cameraGameObject.AddComponent<ArcGISCameraControllerComponent>();
cameraGameObject.AddComponent<ArcGISRebaseComponent>();
var cameraLocationComponent = cameraComponent.GetComponent<ArcGISLocationComponent>();
if (!cameraLocationComponent)
cameraLocationComponent = cameraComponent.gameObject.AddComponent<ArcGISLocationComponent>();
cameraLocationComponent.Position = geographicCoordinates;
cameraLocationComponent.Rotation = new ArcGISRotation(55, 58, 0);
private void Start()
CreateArcGISMapComponent();
CreateArcGISCamera();
CreateSkyComponent();
CreateArcGISMap();
private void CreateSkyComponent()
#if USE_HDRP_PACKAGE
var currentSky = FindObjectOfType<UnityEngine.Rendering.Volume>();
if (currentSky)
ArcGISSkyRepositionComponent skyComponent = currentSky.gameObject.GetComponent<ArcGISSkyRepositionComponent>();
if (!skyComponent)
skyComponent = currentSky.gameObject.AddComponent<ArcGISSkyRepositionComponent>();
if (!skyComponent.arcGISMapComponent)
skyComponent.arcGISMapComponent = arcGISMapComponent;
if (!skyComponent.CameraComponent)
skyComponent.CameraComponent = cameraComponent;
#endif
}And get this errors:
Who can help me a bit with this?
Best regards
