My organization is currently running ArcGIS Enterprise, with a SQL Server back-end, and we're in the process of upgrading to 10.9.1. While the main platform upgrade has been handled successfully, it appears that we're unable to run Network Analyst services on the new version.
We currently use three Network Analyst map services in our workflow:
Routing
Closest Facility
Vehicle Routing Problem
In 10.9.1, we've been able to deploy these services successfully. However, attempts to run these services are failing, as the session log file tables aren't being created. We're receiving the following error in return:
Invalid object name '##SDE_session[SessionID]_[DBID]'
- where SessionID is the relevant Session ID, and DBID is the relevant database ID.
We've looked through the system to ensure that we are using the latest ODBC drivers, and we are connecting to the database; moreover, session tables are being created in the database, as we're seeing "##SDE_[ID]_[SessioniD]_[DBName]" tables in the database.
Is there anything that could lead to our map services being unable to create the named session log tables, or something that we could be overlooking that could lead to this case?
