Since I upgraded from ArcGIS Enteprise 10.9.1 to 11.0, I can successfully create a webgisdr backup but cannot restore it. Whenever I try to restore, it fails for ArcGIS Server with the following error:
Failed to restore the ArcGIS Server:
"code": 500,
"messages": ["Import site failed with the following error. The store implementation is not connected to a config store. Please call the connect method before invoking any other method.", "Import operation failed and an attempt to rollback the site to its original state also failed. The site may be functional but it is recommended that you unregister all machines in the site and create a new site based off the configuration store that was backed up at 'C:\\Users\\foo\\AppData\\Local\\Temp\\tmp-ags-site-14599189019367108479128716508001500\\config-store' and the server directories backed up at 'C:\\Users\\foo\\AppData\\Local\\Temp\\tmp-ags-site-14599189019367108479128716508001500\\directories'."],
"status": "error"
Was able to reproduce on simple sandbox machine with a base ArcGIS Enteprise deployment on which that workflow used to work at 10.9.1.
Any idea ? Maybe @JonathanQuinn ?
All tests done on Windows Server 2019.
Thanks !
