I'm using the MergeLayers task to combine two point feature layers together. I got it working fine except it did not copy the attachments that both feature layers contain. This is described here, but I used the REST API, not ArcGIS Online.
Is there any way to copy/paste attachments from one feature layer to another (possibly with a match on the GlobalID) ?
I can always make a copy of the first layer, export the second as a FGDB and then append this to the copy, but it involves more step, so I wonder if there is a simpler solution to manage & move attachments between layers.
Thanks!
