Is there a way to set the interval of the rulers like you could in ArcMap? In ArcGIS Pro, the further zoomed in, the more tic marks on the rulers which may seem better, but it is difficult to see. In ArcMap, there was a setting for the interval of the rulers. If more intervals were needed, the setting could be changed. In Pro, there does not appear such a setting. The use case is this: in the legend of a map, there are descriptions of variable length. Between descriptions, there should be a consistent gap. In ArcMap, the rulers could be set to 0.1 inches and the guides were easy to see and set consistently. In Pro, the additional dozens of tick marks make it difficult to make the guides a consistent gap. If there is no way to do this, please consider it for a future release.
